Personalized group messaging
I've been using Chomp SMS for group messaging but I don't know that each message is sent individually, or if the recipients can see that others received the same message. How can you tell if the messages get sent individually?
Chomp isn't bad, but I'd like to find a messaging app that will
  • Act as the complete messaging app (handle sending AND receiving texts)
  • personalize each message with the recipients name (like Mass Text Personalizer)
  • save templates for sending AND replying
  • not let the recipients Reply All and see that others received the text
Is there such an app that does ALL of that?
Unfortunately for you, I don't think there is such an app including all these features. But there are some of the features you want in interesting android App.
Regarding your concern about how to personalize your SMS, I will recommand you to use Group SMS.
Group SMS allows you send personalized SMS to your recepients (indeed, "Group SMS" will change special keywords with the Firstname or Lastname of your recipient => the message becomes personalized :).
The SMS are sent individually (one after the other). So there is no "reply all" issue when others receive the message.
Group SMS does not handle receiving message. It's a sending app with relevant features for Group SMS texting.
- Standart version on Android market : https://play.google.com/store/apps/details?id=com.mobappli.groupsms
- Pro version on Android market: https://play.google.com/store/apps/details?id=com.mobappli.groupsmspro
- description on the forum : http://androidforums.com/android-applications/504699-app-group-sms.html
I hope this app will let help you in finding what you are looking for.
Try it, you won't be disappointed :)
