Phone bending.
Techyfek
My Huawei P20 has a bend in it. I don't know if the phone is meant to be that shape or if overheating is to blame?
Is this another bendgate? (iphone reference) :p
Jokes aside, the P20 is as straight as an arrow. There's no bend to it.
Overheating the cause? I wouldn't think so. If it's bendable that sounds more like it spends a lot of time in someone's back pocket and they sit on it a lot. At this point you should make sure any saved data is safely backed up. The internal components in your P20 aren't flexible by design so bending it could really shorten its life span.
