My USB cable is quite loose whenever I plug it in. I need to fiddle quite a lot for the phone to even recognize that it's charging, and even then, the percentage doesn't go up (I managed to charge it once but have been unlucky since). I feel like I should mention that the charging issues were preceding by dropping the phone in the sink with running water screen up a couple of times, but I managed to grab the phone in ~2 seconds, safely shut it down and leave it open to dry for a full day in both cases. It has been at least two months since the aforementioned incident so I assume the phone is and safe from short circuit and potential corrosion? (Because if any water was left to cause the corrosion I doubt I would have a working phone now). One thing that has changed since water damage apart from charging issues is that the battery seems to go down at a quicker rate. I did all the basic troubleshooting (different cable, wall adapter, plug to PC, etc.) with no effect. Cleaning out the port also didn't help as the cable is still loose. Could this be caused by water? Is there no way than to replace the port? Any and all help appreciated
(Attaching USB port pictures, quality is the best I could.)
https://imgur.com/a/VJ1Qrg3
