Martyn27
I noticed the other day my phone is charging at 1/5 the speed it used to. I used to get fast charging but for some reason a full charge normally takes 4-5 hours. I tried different wires/sockets and still no joy. I have double checked to make sure fast charging is enabled too.
I contacted 3 today and went through their usually steps and no joy - they then asked me to finally do a factory reset to check if this fixes the problem. I attempted to connect my phone to my PC (windows 10) to backup my data and got the error "USB device not recognised". I had a look in devices and it says that Device Descriptor Request Failed "Windows has stopped the device because it has reported problems (Code 43). I attempted on another PC and it does not connect to that either - so I think it is a phone fault.
Are these two likely connected? Does it appear that my USB port is faulty? I dont want to do a factory reset if it is not likely to help - I have googled around trying to fix this for a while and no joy.
