Root Phone dead?
iammas
I flashed successful my racer with ricktwyatt's Rom (used recoverymanager & clockwork 3.0.0.5). I tried to partition my sd-card with minitool partition wizard on windows 7 (fat32 & ex3). Did something very wrong, i think, because now the racer won't start anymore (startscreen in loop). Is my phone dead or is there way to start the phone again ? I still have a copy of all files who were on sd before partition (copy, not image).
start the phone up in clockwork mod hold down the volume down button and press the power button once keep holding the volume down button.
you will need to flash the rom again.
That doesn't work with my phone. I can't fastboot or run recovery with the volume/power buttons. I could only boot in recovery mode from recoverymanager. Nothing is changed in my phone's system, i only lost everything on sdcard. So the problem most be the card. Are there systemfiles on sd needed to start the racer?
no none what so ever what happens when you hold down the volume up then press the power key still holding the volume up.
No, no, volume+/- & power doesn't work on my phone (strange i know). The phone worked perfect with rickywyatt's rom (installed with recoverymanager/clockworkmod 3.0.0.5). I removed the sdcard to partition it on PC. Back in the phone everything worked well, only I got the warning that the sdcard was damaged. Removed again, tried again partitioning (did something terrible wrong i guess), back in phone; don't start anymore (loops on zte quite brilliant-screen). Think nothing is changed in phone's system. Think racer will never start again.
well when you Hold down the up volume button and press the power button keep holding the up volume button and dont let go a green android logo should come on hold the up volume button for 5 more seconds if this happens reply back.
No, i've tried this 100 times. It didn't work before i started the flash procedure, nor afterwards. That's why i had to use recoverymanager (to enter recoverymode). I really don't know why fastboot doesn't work on my phone. And i don't understand why my phone doesn't start after a wrong partition/format of the sd (which i did on PC, not on phone).
well if the android logo doesnt stay on like in the picture below by holding down the UP Volume Button and pressing the power key once ( my phone )
then there has been an internal error and cannot be fixed well im not sure of any progrm that will flash it now.
