AndroidAnimal
I've recently picked up the Apollo and have noticed a problem with more than 75% of incoming calls going straight to voicemail, and often calls to and from the phone appear as long distance. (I believe these are related)
I've done a fair amount of testing and research on the problem and I've had long conversations with my providers tech support. I am certain it's not a network issue. Also I have discovered that if I remove the SD card from the phone the problem goes away, but I don't like this solution due to the minuscule internal memory of the phone.
I guess I'm hoping someone here has some insight into this problem and can suggest a solution or work around.
Thanks.
Thanks.
