Root Phone has gone crazy
DMedina559
My phone has started acting really dumb stating this morning(was running CM12, now there's no system on it), it went to an all blue screen, then it turned off, now it doesn't turn on, and when it does it just does the same thing, when in recovery IT DOES THE SAME THING, so i don't think its a ROM thing, and only once have i gotten a purple screen with demigod crash handler asking for ram dump crap, i did wipe system and internal memory, i tried re-installing CM11 and CM12, i tried simplicity but fails to install as there's no build.prop
My commuter is running linux mint 17, if thatll help anything
any help is greatly appreciate!
does that work with linux? i cant seem, to find one for linux
and its hard to get the phone to turn on, there's time it does, there's times it doesnt
no i do not, this one did have it preinstalled but my bro wiped it out with linux and i cant get win7 back
Have you edited the updater-script to take out the build.prop verification and tried to sideload the ROM or maybe even push it to internal when in recovery with adb? Those seem to be your only two options so I hope it helps :)
it doesnt even turn on anymore, and when it does it just flashes lg logo, so im just going to have to get a replacement
If you had the recovery flashed to laf, you could have done it that way.... Or tried WINE, or tried virtualboxing a nabbed copy of windows....
