Help phone i was given to stuck on fastboot and rescue
ryuu 19
so a while back i had my friend buy his new phone for his birthday and he gave me his old one its an huawei y6 scl-l01 or something like that he gave it to me with out the box though and when i tried flashing a twrp recovery on it few weeks ago i failed and the phone still worked, but few weeks later i try to boot into recovery mode and then the phone gets stuck on this white interface with the android guy standing up saying ******PHONE UNLOCKED and FRP LOCK fast boot and rescue mode please connect a usb cable to your computer and open hi suite******* i do have a computer wich i am writing on now, if i could get some help i would appreciate it ...
i have it in front of me as i write this thread but i really cannot fix it i tried giving it to some guy in my town and he said he has no goddamn idea what is happening or why so i really dont know if its broken forever or i can still fix it if it is broken forever ill just throw it away aanyway.
There are a couple of partitions on your phone that will work independently so if one gets messed up it doesn't mean the others are too. It sounds like in your attempt to flash TWRP you messed up your recovery partition. The message you are seeing is from Huawei's fastboot utility which is where you go if a boot fails. Since you were trying to boot into recovery and it's broken, this is where you'll end up.
I don't have a Huawei phone, nor have I ever flashed one, but this is telling me that in this mode you can flash the factory firmware using HI suite. Be advised, though, that if you do, it will most likely wipe your phone, so make sure you have everything backed up first.
I've already tried hi suite and whenever I go to the recovery option I only fin two models if you could give me some easy way of doing it I would gladly do it
Get stock firmware, extract it then get the update.app file. Make a folder named dload on the SD card. Put the update.app file in the dload folder. Boot into the stock recovery and it'll install.
