Help phone keeps restarting when low battery
  • Thread starter Thread starter DeletedMember1930430
  • Start date Start date
D
Guest
Hi my phone keeps restarting when it has a low battery. It usually does around 10% or 20% or even higher sometimes. It boots up onto loading screen then just boots up again then just goes blank. Can anyone help me as this is doing my head in. Does it need a new battery as i am on holiday at the moment
Try and get a genuine one if you can, some of the cheap ones on eBay are crap, my last one was a non original but came highly recommended and I have to admit it is a great battery. Phil
Okay pal i brought the one you recommend works perfectly thanks
