you might need to format battery stat.
I believe there is a battery stat app in the market for the x10
Exactly same problem am having...are you sure replacing the battery will resolve this issue?.I forgot to update this.
I bought two new battery's off ebay for $6.
Guess the battery got screwed.
Works great now, doesnt shut off at all. Im so happy because I would literally not use my phone in less I had too in fear of shutting off...
