Help Phone LCD not displaying anything! Help!
My phone was workign fine until a few moments ago, i had it in my pocket as i usually do and now the screen is just dark. I tried taking out the battery numerous times, and no luck. Its definetly on, i can hear the soudns when i press the button but nothing displays, anyway to fix this?
That's weird.
Have you pressed the power key on top of the phone to unlock the screen?
Have you changed any weird settings like screen resolution or anything like that?
If neither of those things, and no one else have any ideas either, you may have a bad device or screen.
Have you dropped it or got it wet?
If none of the above apply, or get you going in the right direction, you may have to warranty the phone. Make sure you unroot (if possible) first if you need to take it back to the store!
