A
Android Question
Guest
Hi,
I am using a htc explorer A310e. I proceeded to root the phone yesterday and the entire process got done perfectly. After the process I installed rootchecker and I was informed that I had successfully rooted my device. After this, I proceeded to install a custom ROM ( The S.H.T.D ROM from this site: theappjuice.com/best-htc-explorer-custom-roms).
After flashing Superuser, and the ROM files as well, my phone seemed to be ok.
Today, I downloaded link2sd on my phone and tried to move apps from my phone memory to the external (I followed the protocol of making partitions on the ext. memory first etc..)
I open the link2sd app>
I'm looking at a box that required me to select the file system of my SD card's second partition>
I select ext2 and click ok>
I'm given a root access warning message ("Link2sd could not obtain root access. If you have root access make sure you respond 'Allow' or 'Grant' to the superuser request.")
So, I go open the Superuser app and I proceed to update my su binary (as per a few tutorial videos I watched).
I try to update. It successfully proceeds up to the point where "Download new binary_okay!"
But then next, "Gaining root access_fail!"
I tried plenty of things like clearing the data for superuser app and then trying again, rebooting my phone etc. Nothing is helping.
After trying everything I could, I looked into the Rootchecker app again and Now I'm told that my phone does not have proper root access.
Please help me. I'm so worried. I'm starting to think the rooting process didn't happen properly and my phone might end up being bricked. :|
(p.s. I'm very new to this. This is also my first time rooting.)
