Have you tried to add the phone through device manager? I use Win 7 and the procedure is slightly different. Do you see a device with a yellow triangle alongside? If not, it's not a case of no drivers, its a case of not being seen at all so I would try another lead. If you can see the yellow triangle, clock on it and follow the onscreen messages and get it to do a web search for drivers
