Help Phone not waking up
ConnorEfc
Basically, I'll be doing something on my phone and decide to lock it and if I try to unlock it straight away nothing happens and the phone appears to be none-responsive. I can see the backlight for the screen turning on as the phone tries to unlock but nothing happens..
Its becoming a problem because if i lock the phone by mistake I cant get back on for 5+ minutes sometimes without rebooting the phone.
It might be worth noting that I had this issue a while back and it fixed itself after a few months of usage, but I recently factory reset my phone and for some reason the issue came back (It probably has something todo with one of the pre-installed apps or settings)
Running android version 4.4.2 (is rooted but the problem was happening before the root)
Any help is appreciated, thanks in advance!
