phone not working after water damage help needed!
  • Start date Start date
A
Android Question
Guest
hey! my samsung S advance fell into the wash basin and the tap was on ! i kept the phone in sunlight for 1-2 hrs and the phone switched on but the touch screen aint working captive buttons are working and hardware buttons too help me ou !!
You need to power it off immediately and remove the battery.
Then it needs to be completely dry before you turn it on again. If you haven't got a dessicant, the suggested method is to put it in a jar of uncooked rice, which will draw the water out. Leave it there for a day or two - a couple of hours is absolutely not enough.
After that, it's a matter of whether any damage has already been done. We can only hope.
Good luck!
