phone not working
arkangeluk
ok guys, my phone finally stopped working last night, it just cut out. ive tried seus even updating that. went through the updating on my phone but it still wont switch on. when i try to switch it on i get a red light flashing three times and no start up.any help welcome. im due an upgrade 15th june so its only about 11 or 12 weeks to go i think but i dont want to be stuck with a pre android phone till then, i dont know how ill cope lol
ric
ric
Visit a store that sells the phone and test using a replacement battery.
ive already tried sues but all it is doing is telling me phone is fine and letting me update the phone. no option to repair. after i update, when i try to switch it on i get a red light flashing three times
ric
ric
If you can't use SEUS to fix it. Find an old ROM for 2.1 or something and use the Flashtool to flash to an older version.
Then use SEUS to repair/update it.
ok phone seemed to come back on itself today but it keeps swiching on and off. i have flashtool and still have a zip of a 2.1 rom but cant remember how to do it lol. phone is running 2.3 just now
ric
ok update time. i reflashed a 2.1 then hooked up seus and updated to 2.3 and thought everything was going ok but the phone keeps shutting down now. hope someone can suggest any other way to help me fix. ive only been a week without an android phone and the withdrawal symptoms are kicking in lol
ric
ric
After installing 2.3, do a factory reset again (even if it just went through the setup wizard.
It would be a good idea maybe to reset the battery recalibrator or something
https://play.google.com/store/apps/...ls.battery.callibration&feature=search_result
Something that might reset the battery stats, or try using your wife's battery again.
Or if your phone is rooted use this:
https://play.google.com/store/apps/...xLDEsImNvbS5uZW1hLmJhdHRlcnljYWxpYnJhdGlvbiJd
Hi android
now im very upset -
A month ago - I have and i got problem of memory - ( no memory card - and not recognized and all of this word about the memory proplems ) i fixed this proplem manytime by repair or updat my xperia x10 - and
This method solved the problem for days just days - and after i send some song or pic to my phone - after some days this song or pic Disappear again from the gallery or from memory -
Why do my stuff disappear from memory and from my phone ???
i formate my memory several times - NTFS / AND Tryes alsow FAT 32 And this is not fixed the proplem > and when i go to storeg in my phone i see : Erase SD card is hidden
i can not use my camera - why android why ???
Why the camera strapped memory - i updated my phone manytime and i repaired my phone manytime i used sony pc comp - or pc update programs - and alsow this is not fixed my proplem .
the proplem is not in the phone - the proplem in android 2.3.3 .
Because - after downloading the new system from a updated or repaired - solve the problem for days or just hours - and back again >
and I do a search on the internet about this problem - and found that a lot lot of Android phones have a problem and got the same problem .
Android - i can not use my camera - What I want from the phone if he does not have a camera??
What is the solution now
Hi android
now im very upset -
A month ago-I have and i got problemof memory - ( no memory card - and not recognized and all of this word about the memory proplems ) i fixed this proplem manytime by repair or updat my xperia x10 - and
This methodsolvedthe problemfor days just days - and after i send some song or pic to my phone - after some days this song or pic Disappearagainfrom the galleryor frommemory -
Why domy stuffdisappear frommemoryand frommy phone ???
Whythe camerastrappedmemory - i updated my phone manytime and i repaired my phone manytime i used sony pc comp - or pc update programs - and alsow this is not fixed my proplem .
Because-after downloadingthe new system froma updatedorrepaired- solve the problemfor daysor justhours -andbackagain >
and Idoa search onthe internetaboutthis problem-and foundthat a lot lot of Androidphoneshave aproblem and gotthe sameproblem .
Android - i can not use my camera - WhatI wantfrom the phoneif hedoes not have acamera??
What is the solutionnow
Not sure why you thought typing in a larger font and centering it would help get your question answered quicker....but,
You are suppose to format SD card from phone...on phone, unmount card, format sd card, then mount sd card. If you can't format the sd card (not erase) then make sure there isn't any switch on the card making it read-only.
Or download a different camera app like Camera360. In Camera360 you can specify where you want pictures to be saved.
Also, when you upgrade from 2.1 to 2.3, you are suppose to do a factory reset wiping out all old data from 2.1 before you start using 2.3. Try that if problems persist. (that will also cause a problem if you are having problems on with the SD card)
ok update time again. phone seems to be working again although it did shut down today still showing 23% but not to bothered about that. i have recalibrated the battery so will just see how it goes from here. hope it lasts till june till i can upgrade to new phone
ric
