Phone Only Plays Default Ringer - Pllllease Help
I have SCOURED this forum - and others - in search of an answer for my problem and have simply not found it.
I accidently set up a ringtone to be the default ringer. Which is no big deal, except that now none of my custom ringers work. No matter who calls, it plays the default ringer.
I have tried to change the custom ringer to something else (contact, options - and it says the correct name...plays the correct ringer when demo-ed), and change it back to what I wanted originally - didn't work.
Tried changing the default ringer and repeating the above - didn't work.
Tried using two different ringer apps from the market - didn't work.
I do not use any type of task killer, and don't know the slightest thing about rooting or anything of that nature.
I restarted the phone several times.
Also took the battery out while still on...didn't work.
After all that...still rings the default ringer EVERY time.
I'm at a total loss.
Any suggestions? Thankyou
Weird - I set up a default ringer for those times when you get a call from no one you know, then I individually assigned a ringtone for everyone on my contacts list. Works as it should, sorry I can't help more :(
