phone only works in speaker phone mode
  • Start date Start date
A
Android Question
Guest
my phone will not work in regular phone mode it will only work when i turn the speaker on
So you can't hear anyone unless it's on speaker? Try re-starting the phone, turn off then back on. And it that doesn't remedy it, it may well be faulty.
Hi and welcome to Android Forums!
Have you tried a battery pull or reboot? That's what I would try first. Failing that, you might have a dead speaker. I would take it back to where you bought it and have them look at it.
Hope that helps!
