hi!
I recently formatted my mobile and my SD card and tried the alternative for rooting thingy (http://androidforums.com/samsung-ga...-force-install-apps-sd-card-without-root.html).
Then i thought it worked and downloaded lots of apps. Everything looked fine,i even installed App2SD just to double check if it really worked.However, it does not seem to be working since my internal memory is full and my SD card is still empty i guess.
Is there a problem with my mobile?The apps clearly isn't installed on my SD,right?
