Good evening guys!
I have a problem with my Neken N6 android smartphone.
Every time I plug it to a PC, when I then select the option to unmount the internal SD card and mount it to the PC, the phone suddenly reboots.
Happens when clicking this button:
http://s24.postimg.org/dv5xjqr2t/2014_07_01_17_33_14.png
After breaking, when reboot, the SIM card configuration is broken
http://s24.postimg.org/d9gynmw0l/2014_07_01_17_34_32.png
That wan't happening when I bought it, but I don't know which app is making the difference since the problem started.
I've looked to the apps on the SD card and I don't imagine any of them crashing the phone because of a forced closing: none of them are system-related.
Is there any way to see information about what makes the system crash? Any log, dump, etc?
Thank you in advance!
