whereinsussex
Hi all
Here's my problem of the week:
When I connect the USB lead to my PC, all is fine with the world, the "three pronged" USB symbol appears in the top left of the screen and I can "mount" it.
Now, if I have just turned the phone on, I can mount/unmount with no problems, as I did last night, couldn't recreate the "fault" I am about to describe.
Went to bed, got up, plugged in to laptop, three pronged fork appears in the top left, select mount, SE logo fills screen, phone has a soft reboot and asks for the PIN for the SIM card.
Now, rather than the three pronged fork, I get an ! in a triangle icon, but can still mount/unmount.
So the question is, why does the phone sometimes reboot when I mount the USB and then why does it appear as an ! after this.
It never appears to reboot when it is an !, only a three pronged fork., and to restore the USB fork icon, I have to switch off and on again.
Any ideas?
Steve
Any ideas?
Steve
Plug in > Mount > Reboot > USB now "!" symbol and won't change from it, although it will mount.
