Phone seems to use a lot of data - when Im not using it ?
AirCatHeavy
Hi,
I installed Net Counter and notice now that my phone seems to use a lot of data even when I'm not using it.
I know it checks email and does some background updating but now that I can see the usage, I'm wondering how much is normal?
For example, about every 8 hours it will use 3 or 4 MB without me even using it.
Is that normal? I hope so.
Hi,
Try an app called 3 G watchdog net counter is terrible,also are you connecting to WIFI when available.
Hello,
Ok, I'll try 3G Watchdog.
I don't use wifi and leave it turned off.
I also set ALL my apps NOT to update automatically.
I still get quite a bit of bandwidth usage for reasons I don't understand.
