mjschmidt
Android Expert
Would love to see this. An app that allows the user to set up multiple one-click profiles for phone settings. I have tried Locale, but Locale only allows for control of a small number of settings. I would like to be able to create custom profiles and switch between them with shortcuts on the desktop, or from the notification bar.
For example:
Profile 1 (Power Saver)
APNs = off
WiFi = Off
BT = Off
Background Data = Off
Sync = Off
Brightness = (user's choice, I set to 9%)
GPS = Off
Wireless Location = Off
This profile saves battery power the best. I would like to be able to switch back to a "Power User" mode (all of these things turned ON) with one press.
I'd also like to set up one-click profiles with variations on these settings, in case I just want to change the BT or WiFi.
Also settings for Volume, etc.
basically one-touch user customizable settings profiles for _all_ settings.
For example:
APNs = off
WiFi = Off
BT = Off
Sync = Off
GPS = Off
