Help Phone stuck on boot loop after factory reset.
Jaxontuck
Earlier today I dropped my phone from a small height, maybe one to two inches, and the phone rebooted itself into an update screen. A few seconds after this I was met with the "no command" error screen. When I got home I did some searches on the internet and performed a factory reset but, after the reset I rebooted my phone and now it is stuck in a reboot loop. How do I solve this?
Check your Sim and SD cards.
Maybe remove them completely to test if the phone would boot normally.
If all else fails, a reflash of the stock firmware in odin should fix it assuming there is no hardware damage from dropping it.
Honestly it sounds like one of the buttons is stuck which is booting you into recovery or a bootloop. Try wiggling them a little to see if there is any change in behavior.
