Phone wet no wifi connection
  • Start date Start date
A
Android Question
Guest
I got my phone wet at the pool, and I dried it in rice and everything is working except it wont connect to ANY wifi, the wifi wont even turn on..how do I fix this?
Honestly, it is possible that you shorted out the wifi radio portion of your phone. I did something similar with my Galaxy Nexus to the LTE radio.
The only resolution, besides putting it in some more dry rice for another couple of days, is to get a replacement phone.
Hope that helps, and we'll see you around the forums!
