Dear android community. I come to you in tears. I did a factory reset from the setting panel and my phone rebooted but would just get stuck on the android image during bootup. From recovery mode I tried restoring a backup and that did the same. I even tried running the update.zip that was on my sd card. No luck! I was running Glax0 I believe on I4 or whichever IX that Galax0 was meant for. From recovery mode I can access the sdcards. Is there some .zip file I can run such that I can boot my phone up. I'll take anything for now. These problems sounds strange. I just hope my phone isn't knackered. Any help from you guys would be really appreciated.
