Phone won't connect to home Wifi - doesn't show network
mros
My Honor 9 lite won't connect to my home wifi.
I have a new router that I installed 2 weeks ago. Everything was working fine until yesterday. My computer and tablet connect with no problem, however my phone does not even display the network anymore.
My phone displays all of the other networks nearby, but not my own. It is also able to connect to other networks without any problems.
I have tried restarting my phone, turning wifi on and off, airplane mode on and off, "forget network", manually adding my network, "WPS Connection" fix...I'm not sure what else to do other than a factory reset (which I'd like to avoid)
Especially weird because it was working fine for 2 weeks and then one day it just decided to stop for no apparent reason (I didn't update the software in that time frame).
I'd really appreciate any advice on what else I can try!
