Root Phone won't reboot into recovery.
Hey, lurked for a while, but finally joined. I have recently started to try out different ROM's for my phone and I am currently using Cyanomodgen 7.2 from the link in the sticky page. Its OK, but I'm not sure if its the ROM for me. I'm trying to flash my phone into Mate35, but I am having a problem. When I try to boot my phone into recovery, I think my phone crashes and it just reboots as normal. When I try to boot it into recovery, the phone will restart, vibrate, go into the Huawei intro photo, wait for about 3 seconds, go black, vibrates again, shows the Huawei photo again, see the CM7 blue Androids stacked on top of each other, see the one falling off a skateboard with the blue circle around him, yells DROID!, and boots back into CM7.
Am I doing something wrong here? Does CM7 delete the recovery page altogether? Do I need a certain version of Clockwarkmod for it to boot into recovery for this phone?
Idk wat happened but I suggest flashing recovery via fast boot. Since you can't. Flash with Tom manager cause you need wifi. .. and yu can use my recovery tools if you're on windows 7, Linux or Mac
Are you using ROM manager to do your rooting? If so, try flashing a different recovery. The Huawei Ascend one works well for my M835 w/ CM7.2
