Help Phone wont start after ODIN flash with xxjpo
I have tried to get my phone to work but it seems that it will not boot after i have attempted to flash it....
I have used all the different pit files and used odin 1.3 and 1.7 and neither of them work. I have tried using JPX, JPY and JPO/JPP and nothing.
it shows:
update media, please wait
E:Can't mount /dev/block/st110
(Invalid argument)
E:copy_dbdata_media:Cant's mount
your storage not prepared yet, please use UI me
nu for format and reboot actions
copy default media content failed
It wont let me use the format sd card option either?
I did have the one click lag fix installed but did a factory reset before i tried to flash it.
help!
SOLVED!
Ok thanks for the speedy reply...i have fixed it this is what i did.....
I was on froyo 2.2 version xxjpp . Then I read in samfirmware . com that to flash this firmware we had to go back to 2.1 xwjm8, and flash with repartition selected and 512 pit. I put CODE_I9000XWJM8.tar.md5 in PDA and MODEM_I9000XXJM4.tar.md5 in phone. I did that with download mode and odin 1.3 and It seemed as if I was back to square one when the screen got stuck at splash level but when I took out the battery and switched on it booted in to 2.1 firmware. I went in to download mode again and flashed 803 pit with 2.2 firmware (JPO_JPO_U_JPP.tar) with repartition unselected and I am back to 2.2 froyo again and happy .
