Phone wont start up
  • Start date Start date
A
Android Question
Guest
I just bought an HTC Droid Incredible. I was to upload a picture to facebook and the phone just shut off. I tried taking out the battery over night and it still won't start up. It goes as far as the symbol and saying DROID and goes back to the symbol and will not start up.
Did you charge the battery? Removing a low battery and putting it back in will still cause it to shut down during boot up when it realizes the battery is low.
you can try key combination to enter recovery mode, and try to reboot, if that didn't work try factory reset.
for that press and hold vol button and power button together while the phone is turned off.
and. there is options for reboot and clear data.
clearing data (factory reset) will erase all your saved data on phone memory
if u want to know more try our link given below
androidforums.com/htc-droid-incredible/
