Help Phone wont Vibrate for texts
Antman27
Member
What happend ?? I used this all the time and now it wont work ? In sound settings Vibrate is selected always on
In message settings Vibrate is checked
What am I missing ??
If your running a custom rom then I suggest a reflash.
If running stock try a battery pull while the phone is on and reboot, or a factory reset. Now granted it does vibrate on other options correct?
