phone
  • Start date Start date
A
Android Question
Guest
I have no signal on my phone can I use a app to get signal? if I can what would that be please help asap thank you
Hello and welcome to Android Forums.
Did you previously have a signal and now don't? If so contact you service provider and see if antenna work is being done in your area.
Have you made changes to your phone? Installing a new ROM often times requires upgrading your modem (software).
Does your phone have a known issue? You did not list your make/model so I cannot check.
Are you in a building or around unforgiving topography? Many things can block cell signals.
More detailed information can narrow down your issue and help us diagnose.
You can easily resubmit another question using the same
