Photo organizer?
Slowtdi
Its there such an app that would let me organize photos into different categories, but be viewable like in the gallery?
For example, I would like to click on a folder that contains all of my car photos, then be able to see them all with thumbnails. The stock gallery doesnt let me organize in such a
way.
Thanks,
I domt know of an App but I have created a folder called Piccies on my SD card then sub folders for catergories. Your album will pick this up once set up then you can put your pictures in the appropiate folder.
I did some more searching.
You can create new folders and move your pictures to the sd card and it will show your new folders in the gallery. I thought i had tried that before, but I must have given up to soon. It took a bit for the gallery to update..
Also, for a quicker approach, there is "ctrl folder". That way you go into share and select the folder you want to put it in, and it also let's you choose whether you want that folder to be seen in the gallery or not.
Problem solved, thanks for stopping by.
