Help photo problem
Hello stinker!
Easiest way I found is to go to the DB app on your device, choose the photo, hit the menu (3 dot icon) and choose to export to device. It will ask you where to save it to. Choose internal, then DCIM/camera. You can then find it in your gallery under DCIM/camera. ;)
Hello stinker!
Thank you- however Internal is not listed as an option???
What other options are offered?
You could also download it via pc, to the pc, and move it manually via the pc to phone.
Edit: there may be another way to do it and perhaps someone else will chime in, but that's the way I do it;)
I can do that BUT I cannot move photo from dropbox to gallery to put in an album!! thank you!! stinker
You should be able to use a file explorer that supports cloud storage and copy or move files that way. I use root explorer. On the bottom of the screen there is a plus sign button (+) where you can add folders, external storage, etc. Choose "Dropbox Tab" and authorize your dropbox account and you are good to go.:thumbsupdroid:
