There are two methods I use, one is by using a File Manager which I'm sure most devices come equipped with but there are a number of excellent ones to be found on Play Store. My HTC device has the HTC File Manager which meets all my requirements so I have no experience of any others. With a file manager you can copy or move your photos, or any other file, from Internal Storage to SD card and vice versa. You can create new folders if required.
The second method I use is to connect the device to a Laptop/PC and then use the copy/move function.
You should also be able to select which storage area to store newly taken photos from the settings options in your camera app.
I wrote an app just to do this if it helps. Its free. I encountered similar issues from Android Kitkat onwards. This will automatically copy / move files from one folder to another on the SD Card.
