Pryomancer
I've got a problem with some PHP code I'm writing.
The aim is for the user to enter the id of a song from a database.
The page then reloads with the information of that song displayed automatically in a form. The user can then edit what they need and submit it. That form passes the info to another page which executes the sql update query.
I've got the first two pages done, where the user enters an id, and then the page reloads to display the autofilled form.
But it doesn't actually update the records. I've been stuck on it for a number of hours now, I can't find the problem.
Here's the code for the page that reads in the id and displays the autofilled form:
This code outputs:
This is the PHP that handles the information from this form, and executes the sql:
The code runs, I don't get any errors, it displays the page saying 'Records updated.' So as far as I can tell the process is not erroneous. It just doesn't update the database.
Can anyone help?
PHP:
<?php
//Connect to database
$con = mysql_connect("localhost", "root");
mysql_select_db("dfti");
$a = $_POST["id"];
$result = mysql_query ("select * from hits where id='$a'");
while($row = mysql_fetch_array($result))
echo
"<table><br /><br />
<a href=\"updatedetails.html\">Back to Update Details</a>
<p>
<tr>
<td> ID </td>
<td> Song </td>
<td> Artist </td>
<td> Year </td>
<td> Amount </td>
<td> Price </td>
<td> Genre </td>
</tr>
<tr>
<td> $row[ID] <br /><br /></td>
<td> $row[song] <br /><br /></td>
<td> $row[artist] <br /><br /></td>
<td> $row[year] <br /><br /></td>
<td> $row[amount] <br /><br /></td>
<td> $row[price] <br /><br /></td>
<td> $row[genre] <br /><br /></td>
</tr>
</p>
</table>";
mysql_close($con);
<?php
$a = $_POST["id"];
$result1 = mysql_query ("select * from hits where id='$a'");
$row1 = mysql_fetch_array($result1) ?>
<table>
<form method="post" action="updatedetails2.php">
<tr><td>ID:</td> <td><input name="id" type="hidden" id="id" value="<?php echo "$row1[ID]";?>"></td><td><?php echo "$row1[ID]";?><br /></td></tr>
<tr><td>Song:</td> <td><input name="song" type="text" id="song" value="<?php echo "$row1[song]";?>"><br /></td></tr>
<tr><td>Artist:</td> <td><input name="artist" type="text" id="artist" value="<?php echo "$row1[artist]";?>"><br /></td></tr>
<tr><td>Year:</td> <td><input name="year" type="text" id="year" value="<?php echo "$row1[year]";?>"><br /></td></tr>
<tr><td>Amount:</td> <td><input name="amount" type="text" id="amount" value="<?php echo "$row1[amount]";?>"><br /></td></tr>
<tr><td>Price:</td> <td><input name="price" type="text" id="price" value="<?php echo "$row1[price]";?>"><br /></td></tr>
<tr><td>Genre:</td> <td><input name="genre" type="text" id="genre" value="<?php echo "$row1[genre]";?>"></td></tr>
<tr><td><input type="submit" value="Confirm"/></td></tr>
</form>
</table>
PHP:
<?php
$id = $_POST["id"];
$song = $_POST["song"];
$artist = $_POST["artist"];
$year = $_POST["year"];
$amount = $_POST["amount"];
$price = $_POST["price"];
$genre = $_POST["genre"];
mysql_query("UPDATE hits SET song=$song, artist=$artist, year=$year, amount=$amount, price=$price, genre=$genre WHERE id=$id");
echo "Records updated.<br /><br />";
echo "<a href=\"updatedetails.html\">Back to Update Details</a>";
mysql_close($con);
Can anyone help?
