pix3 much slower charging than pix2?
hi CS,
ah ok - not pix charger as never had one .... but same anker usb c as used with pix2 .... but then the battery on the pix2 was a bit knackered :D
thanks will try that app to check it
ta
hi CS,
ta
It can be a trial in patience if you do not use the included cords. Even though I have 45w wall plugs, certain cords will fast charge one phone and not the other. No rhyme or reason why.
App is best way to know for sure. Plus, I HATE the Pixel 3/4 do not indicate fast charging (not wirelessly at least).
looks to be taking approx 1hr15 to charge from 40% to 100 ... and think the power stats were 450ma and 4.8volts ... might be slightly off as i glanced at battery app :D
cheers
I basically keep my pixel 3 plugged in and charging while I am driving. I keep it charging because it seems that Bluetooth drains the battery quicker:thinking: but on the other hand my blue tooth head set can go three days without needing a charge
