GamerCore Android Enthusiast Nov 6, 2017 #1 You can block numbers very easily on the Pixel 2 XL. Here's how you do it. Open the Phone app Click the 3-dot menu button Tap on Settings Tap on Call blocking Tap on Add a number Confirm by tapping Block
F fergiesperson Lurker Dec 13, 2017 #2 GamerCore said: https://www.youtube.com/embed/rrouWIgzg3E?wmode=opaque You can block numbers very easily on the Pixel 2 XL. Here's how you do it. Open the Phone app Click the 3-dot menu button Tap on Settings Tap on Call blocking Tap on Add a number Confirm by tapping Block Click to expand... seriously? I have to input each spam number by hand? I thought I'd found a link from the actual call history, once.
lunatic59 Moderati ergo sum Moderator Dec 13, 2017 #3 fergiesperson said: seriously? I have to input each spam number by hand? I thought I'd found a link from the actual call history, once. Click to expand... I'm not sure if it's there in the Pixel 2, but in most call logs, if you long-press the number it gives you the option to block it.
P pinco000 Newbie Dec 15, 2017 #4 you dont need to input the number. Just go to your desired contact and click on the three dots. Then choose ROUTE TO VOICEMAIL 😉 Last edited: Dec 15, 2017
lunatic59 Moderati ergo sum Moderator Dec 15, 2017 #5 pinco000 said: you dont need to input the number. Just go to your desired contact and click on the three dots. Then choose ROUTE TO VOICEMAIL 😉 Click to expand... That's assuming the number you want to block is a contact.
