Pixel 2 XL: How to send GIFs
GamerCore
Sending GIFs on the Pixel 2 XL is really easy, just follow these simple steps:
  1. Open a messaging app or other app that allows you to send images
  2. Tap the empty text field
  3. Tap the emoji key inside the keyboard (Gboard/Google Keyboard)
  4. Tap on the GIF tab
  5. Browse through GIFs using the search bar inside the keyboard
  6. Tap a GIF to immediately send it
I am wondering if I can use my motion photos to make my GIFs ..(thanks for saying correct pronunciation I try to tell people same thing )
