CatAndMaus
Hey
I have run into an issue with Android Print. We print from Android devices but get a pixelated text (at the edges of each character) and sometimes random holes/gaps in lines or characters.
The following printers are used:
The print job is send via a wireless connection.
We have tried the following variants for printing:
* Samsung & Brother Print Services:
both using Apps like Adobe Reader and our own app (printHelper, printManager,...)
*Samsung Mobile Print App
Directly print a pdf or image (jpeg, png) and through our app
*Samsung Cloud Print
*Brother Mobile Print app
directly print a pdf or image (jpeg, png)
So far we have only been able to get an aceptable quality when printing from desktop (Win 10, Ubuntu 14.04 and 18.04), The printers are all in working order.
We have tested Android 6, 7, 8 and 9 from different devices (tablets and smartphone from different manufacturers like LG, Lenovo, Nexus, Pixel, Huawei,)
We also eliminated that the fault is with our documents by printing pdfs and docx files with arial as the font.
________________________________
Does anyone have any ideas why this happens or an idea how we can fix this?
It is not necessarily required that we use apps or services that are provided by andoid/samsung/brother.
We are also willing to hire someone for fixing this if it turns out to be a huge amount of work or if deep inside knowledge is needed.
Thanks for the help!
- Samsung Xpress M2026W
- Brother HL-L2350DW
