S SixHouse Newbie Sep 4, 2015 #1 I can't tell. Is there a clear plastic sticker over the flash area on the back of the phone?
Amishtech Lurker Sep 4, 2015 #2 yes there is a tiny piece of plastic wrapping around the flash. use caution when removing.
D Deleted User Guest Sep 6, 2015 #4 Is it a scrape, rub, or lift point to remove it? My M8 had one that you had to sort of aggressively scrape off.
K KOLIO Guest Sep 6, 2015 #5 Just on the flash on mine,came off relatively easy. Doesn't appear to be anything like that on the camera lens.
Lauren0125 Newbie Sep 7, 2015 #6 KnirpsLyn said: Is it a scrape, rub, or lift point to remove it? Click to expand... It's a thin film that will lift off. You just have to get under the edge of it (carefully).
jmy7213 Lurker Sep 9, 2015 #7 Hahaha, glad I ran onto this post. Never even realized there was plastic on there. Not anymore, thanks
