Help Play and Gapps installer for Skytex Alpha 2
Rabid1
I have put together a Play and Gapps suite installer for the Alpha 2 ICS . This is not for ICs nor should it be used to try to correct a bungled Play install. Voice Search, Play, Talk all work.
You will need ADB drivers installed to install or install the included ADB Wireless on your tablet before running the appropriate .cmd file. Please read the included instructions.txt
DIRECT DOWNLOAD
