Help Playing Evernote audio
AmHub
Does anyone know of an app or player that will play the Evernote audio notes on SGT 10.1 ?
These are audio files in the .amr type. My Evo plays them but as I use the Tab more with Evernote I need to be able to play the .amr files.
Thanks
Thanks
What application do you use to play these file on your Evo? Use the same one to play them on the Tab.
Thanks the Evo I use the HTC voice recorder. Can you recommend one that plays the .amr format?
Can you not try and use the apk from your Evo?
I ave not seen anything about amr playback anywhere so I cannot recommend anything. Search the Market.
