On my HTC Hero with CM6 I could long press the screen and had the option to add a shortcut to a playlist, not in the stock (Starburst) ROM.
Also I just used file lists saved as .m3u files and hit the shortcut and the playlists started. Now if I open the playlist (on external SD) from inside the player, I get a "not recognized file type" error.
Any idea how to not have to add each song manually to create playlists and use the ones I have?
