supermariotyt
Hi, i am new here. I have recently had a problem with my alcatel Ideal. Th
e playstore kept having an error with the code RH-01. So i later found out you had to remove your google accounts and add them again. I removed my account. then when i tried to add it, it was stuck at a checking info screen. I kept looking at threads to try to fix this, but nothing worked. So i decided i would reset my phone. Now, i have every google app updated but still stuck at checking info. Nothing will work. (Gmail, play store, hangouts, youtube, chrome, google, play music, play movies and tv, play newsstand, etc. basically anything that works with play services.) I can't basically do anything on my phone except use the apps that it came with (besides google stuff) so i can't download apps. Please help Asap. Pictures are above.
Disclaimer: I do not get any errors with the infinite checking info, just a couple google play services has stopped.
