I want to make an app that implements some sort of database system. The app will have multiple tabs on the side, some of which are just used to showcase tables (the content might include photos as well), and some are used for posts (similar to Facebook posts). The app does need the user info, but it doesn't need to verify it. The user then can post something on the post tab, perform searching on the tables, and submit a suggestion form.
Preferences:
1. Since I'm really new to app development, I'd really prefer to work with easier/more popular language and tools
2. It's mainly targeted for Android but wider implementability is of course welcomed
3. The app doesn't need to look amazing or dynamic-ish
Please let me know if you've got any suggestions
Thanks!
Preferences:
Thanks!
