Root Please help, i've changed hex codes to phone
jamess
I was utilizing the goldcard method to root my phone by unlockr.
however i mistakenly changed the hex codes to my phone instead of my sd card.
my screen is greenish and it keeps failing to connect to the network. on top of that a force close box is repeatedly popping up.
what can i do?
I have a mytouch 3g 1.2 (with the jack).
Can anyone provide the 0-170 (including 170)
hex codes so that I can try and fix my phone?
To get the hex codes you can download the HxD hex editor off of download.com.
Then, install the file and run it as an administrator.
After running the file, click on Extras -> open disk.
Under physical disks, there should be a drive (which could be a number of things depending on what is plugged into your computer).
Make sure to choose the phone.
For me, my phone shows up as Hard Disk1.
Uncheck open as readonly, and open the phone.
Now within the code, right click and select Select block or press
Ctrl + E.
Start with the offset 0 and end with offset 170.
Make sure it is on Hex and click Ok.
Then go into edit -> copy.
and if you can reply with the numbers maybe I can fix my phone.
If someone could please help me out...
I really need my phone for work.
Please..
