Hello Thnx for your suggestion
this is what i found working. foll code work for Zoom In-Out image when we scroll.
but i want to make the same for button click. & i failed to show button.
package com.example.zoom;
import android.content.Context;
import android.graphics.Bitmap;
import android.graphics.Canvas;
import android.graphics.Bitmap.Config;
import android.graphics.drawable.Drawable;
import android.graphics.drawable.ShapeDrawable;
import android.graphics.drawable.shapes.ArcShape;
import android.view.KeyEvent;
import android.view.View;
import android.view.ViewGroup;
import android.widget.Button;
import android.widget.RelativeLayout;
import android.widget.RemoteViews;
public class Zoom extends View{
    public Drawable image,b;
    private int zoomControler=20;
    public RelativeLayout rl;
    public View canvas,iv;
    ViewGroup vg;
    Button btn;
    Canvas c;
    public Zoom(Context context)
            super(context);
            iv = (Button) findViewById(R.id.Button01);
            image=context.getResources().getDrawable(R.drawable.icon);
            setFocusable(true);
    @Override
    protected void onDraw(Canvas canvas) {
            // TODO Auto-generated method stub
            super.findViewById(R.id.Button01);
            super.onDraw(canvas);
    //here u can control the width and height of the images........ this line is very important
    image.setBounds((getWidth()/2)-zoomControler, (getHeight()/2)-zoomControler, (getWidth()/2)+zoomControler, (getHeight()/2)+zoomControler);
    image.draw(canvas);
    @Override
    public boolean onKeyDown(int keyCode, KeyEvent event) {
            if(keyCode==KeyEvent.KEYCODE_DPAD_UP)// zoom in
                    zoomControler+=10;
            if(keyCode==KeyEvent.KEYCODE_DPAD_DOWN) // zoom out
                    zoomControler-=10;
            if(zoomControler<10)
                    zoomControler=10;
            invalidate();
            return true;
