Please help my phone XT1766 bricked
If you have your Moto E4 in a case, make sure it hasn't inadvertently shifted and the Volume and the Power buttons aren't being pressed down at startup.
That aside, it sounds like somehow the Android OS has been corrupted. If you want to re-flash with a stock ROM, XDA Developers has a nice thread providing instructions on what you need and what to do:
https://forum.xda-developers.com/mo...de-xt1766-stock-firmware-restoration-t3775347
I have the Moto E4 Plus and had to take a file to a corner near the volume buttons to keep it from being accidentally pressed.. Apparently they make case for the 1st iterations (usually MediaTek) and don't always bother making case adjustments for the other model's differences (like Qualcomm) of the same line.. Food for thought
A bricked Android phone means that your phone is stop working by not responding to any commands. Many reasons can lead to a bricked Android phone and rooting the phone is a common one among them. Well, your phone becomes a bricked phone is not the worst thing, what troubles you a lot is how to restore the entire data saved on it and data loss problem almost drives you mad and desperate. Don't panic, you can easily restore files from your bricked Android phone by Android Data Recovery, which can drive you from the situations above and rescue all the data from bricked Android phone with just one click.
Please provide me link for Android Data Recovery software
