PLEASE HELP Text Message Ringtone
Burbit
Hi! I can not figure out how to change my text message ringtone, please help!
The ringtone for my text messages will not change not matter what I try.
I have tried going into my text message main screen - menu - notification - ringtone BUT this puts the new ringtone on and does not turn off the old ring tone.
I have tried changing my notification ringtone in the app Ringdroid and that changes everything but the text messages.
I'm not sure what to do, any help is appreciated!
Brittny
Have you created a folder called notifications on your SD card? If not, get the app called astro and create one, then put any ringtones you want to use in that folder.
then go to menu/settings/sounds and display/notifications and change it from there.
hope this helps,
Lewis
Its much easier to just download tonepicker from the app store. I tryed everything then downloaded that and it works perfectly on the Nexus One.
